1st use of 2305.
   / 1st use of 2305. #1
Jksnvly
Endless Mntns of Pa.
Well I finally had the opportunity to use my 2305 and LX4 cutter. I made a huge dent in cleaning up the apple orchard area of my upstate property. It hasn't been cut in years and the multiflora was everywhere. I am truly amazed at the capability of this unit. It walked through everything w/o faltering, those compact diesels sure are workhorses.
   / 1st use of 2305. #2
I am also a new member with a 2305 , I have had it since last november and I love this thing!
   / 1st use of 2305. #3
Guys watch those hydro fans. They are really easy to mess up while bushhogging thick stuff. I had nicked mine pretty bad. Luckily it didn't break it like others have done.
Your right though they are little work horses. I had 380 hard use hours on mine when I traded it.
   / 1st use of 2305. #4
Jksnvly,
Glad to hear that you got some good work out of it. It sounds like your first real task was like mine--rough mowing 4'-7' tall weeds. Like you, I was amazed by how easily it cut through the thickest, most dense weeds and woody shrubs as if they were not even there.
I decided in my first mowing to give it a real stress test. I have a pond on my property with an approximately 20' tall 30 degree angle dam. I parked myself at the bottom of the dam, put the tractor in 2wd and mowed straight backwards through 3' tall grass and wild raspberries. The closest it came to faltering for even a moment was when I hit a slick part of grass in which case I simply stepped on dif lock and the tractor effortlessly continued to mow backwards with the LX4 all the way to the top. This is certainly not the best way to use this tractor but it did not matter for one instant. If it can perform under these conditions, I can hardly imagin how it would be stopped.
Have fun with you chores!!
SI2305
JD 2305, CX200, LX4
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
