1st time poster. BX2350 MMM & tiller question
   / 1st time poster. BX2350 MMM & tiller question #1
MatthewsPA
Central PA
BX2350
Hi everyone this is my first post. I have been reading these forums for a while and finally decided to chime in. I actually don't own a tractor but my father has a BX 2350 and I use it and enjoy it just as much as he does but he is not the computer nerd that I am so this question is from both of us.
Is it possible to lock the mower deck in the raised position while using the rear 3-point hitch? We have a tiller for the back and when we till our garden the mover ends up riding on the dirt. We have the wheels on the deck all the way down now so that works but my uncle's John deer has a pin to lock the deck up when using the rear 3-point. Is it possible? Are we missing something?
Thanks everyone.
   / 1st time poster. BX2350 MMM & tiller question #2
If your mower height dial has a "top" setting, that will do the trick. Many of the decks can be pinned up also if you can get the holes to line up.
   / 1st time poster. BX2350 MMM & tiller question #3
You should be able to set the mower cutting height control dial to the "top" position. This will lock the mower in the up position and allow the three point to drop down.
Gary T.
   / 1st time poster. BX2350 MMM & tiller question #4
I guess I need to learn to type faster, Evil the Weasel beat me to it.
   / 1st time poster. BX2350 MMM & tiller question #5
yup- just move the dail to top postion under seat
It still seems to move up and down even when in the top position. I don't know if it's going as low as it does when it is set to a number bit is it supposed to move?
   / 1st time poster. BX2350 MMM & tiller question #7
It will still drop down a bit when in top but not as low. My experience is that you will want to remove the mower to til for the reason you observed. The fix is two tractors. One for tilling and one mowing oh yes and one to FEL work oh and one for...
   / 1st time poster. BX2350 MMM & tiller question #8
I agree with what has been said on this regarding using the TOP setting to lock the MMM in place.
However, I have been having a recurring problem in getting the height adjustment dial to turn completely to the TOP setting on my BX2360. With the deck raised to its max height, the knob will occasionally not want to twist all the way to TOP, a few other other times it has worked fine. Is this just a problem with my relatively new tractor (<40 hrs) which may go away after more break-in use, or a problem I should address wtih the dealer?
Thanks.
   / 1st time poster. BX2350 MMM & tiller question #9
Thanks.
The linkage is out of adjustment and the dealer can correct this. you can see the linkage adjustment from the left rear of the tractor on the three point linkage. mine was delivered in this condition. Best of luck.
   / 1st time poster. BX2350 MMM & tiller question #10
Thanks Tim;
I will see if I can adjust lift linkage myself; if not, I'll address with the dealer at my next visit. Hope you're enjoying your BX2660.
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
JOHM DEERE 1600 WAM LOT NUMBER 125 (A53084)
JOHM DEERE 1600...
