1st Service
/ 1st Service #1
SouthernHunter
Mississippi Coast
Kubota L3430
Hello, I am a new tractor owner and my toy (Kubota L3430) w/FEL is due for it's first service, which my understanding is a complete fluid and filter change. Any recommendations on fluid types, sources. I know my dealer will recommend their brand, but having been an engineer for a long time I know that there are probably better products out there.
Does anyone know who makes the Kubota fluids? I know Harley Davidson does not make the fluids they try to push for my bike!
I am considering going with a syn for the crankcase?
By the way, this site was a real help during my tractor shopping period.
Any suggestions would be greatly appreciated.
Thanks
/ 1st Service #3
I refill the hydraulic reservoir with Kubota Super UDT and use MObil Delvac 1 Synthetic in the crankcase. Maybe unnecessary but the expense is insignificant compared to my investment in the tractor.
Also, I suspect that the engine cranks easier when starting in cold weather, which we get our share of here. /forums/images/graemlins/grin.gif
/ 1st Service
I appreciate you guys helping out, can you tell me how many hours I should put on it prior to changing to the synthetic oil, I want to make sure that everything is worn in and seated. I have 50 hrs on it now.
Thanks,
/ 1st Service #5
That's right at the point where I changed in both of my bota's- 50 hours.
I'm still changing as or more frequently than called for in the maintenance schedule, although I could probably stretch changes out with the syn oil.
/ 1st Service #7
I just recently did mine at 45.5 hours and I am also new to tractor world. My 20+ year old Gravely is just too small for 6.5 acres.
I stayed with SuperUDT and Kubota filters. I also cleaned the hydraulic tranny screen, against the dealer's advice to "not bother." I'm glad I did, because it was loaded with metal shavings.
I did not change the front axle Super UDT but will do that in the spring, and probably use a synthetic like Valvoline, though the cost is about the same.
I thoght it too early to switch to a synthetic for the crankcase, but will do that in the Spring too. No scientific proof on that just a gut feeling. I want the rings to seat well first.
regards,
Steve
/ 1st Service #8
<font color="blue"> Any suggestions would be greatly appreciated. </font>
There are quite a few threads on doing 50 hour service on a L**30.
Here is one that should help. /forums/images/graemlins/grin.gif
Click Here.
/ 1st Service #9
SouthernHunter, since you are so far south, like myself, you can use Kubota UDT instead of Super UDT for the hydraulic/transmission fluid.
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
Gravity Box (A65640)
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2201SFL (A64553)
2201SFL (A64553)
MF GC2300 fel replaced
Wood Fence Post (A62613)
Wood Fence Post...
