1st day on CK25HST,,,impressions
   / 1st day on CK25HST,,,impressions #11
Yoyo ,what is draft control.
Al
   / 1st day on CK25HST,,,impressions #12
I had asked in a different thread a similar question. I was wondering what the difference was between position control and draft control. This is the reply by timb:
3 pt hitches these days are controlled in one of three fashions -
The simplest uses just a 'regular' hydraulic control valve and you move the valve one direction to move the hitch up - and the other to move it down, much like a loader. Some of the SCUTs or smallest CUTs use this approach.
Position Control is more sophisticated - basically - the 'normal' hydraulic control is buried inside the rockshaft system and connected to both your control lever and the hitch. Your control lever is set to a given position and the 3-point raises or lowers to meet that position. This is usually an 'active' arrangement - if there is any leakdown that lets the hitch lower - it should automatically cause the hydraulic fluid to flow and keep the hitch in one place. Position control keeps the hitch steady relative to the tractor and is needed for many rear implements - including rotary cutters, rakes, etc.,.
As far as I know, Draft Control actually predates position control on 3-pt hitches and is similar in that it is an 'active' system - but has an important difference. Instead of setting an absolute position relative to the tractor as with position control - you effectively set a draft load. That load should correspond nominally to a certain depth setting for a plow or cultivator. If the draft load lessens or grows - the hitch will move to try to get back to the same draft loading (not necessarily the same position relative to the tractor). The idea is that the implement will keep a steady pull (hopefully a steady depth) even if the tractor is running over slightly uneven terrain or the plow encounters an obstruction. Draft control is critical if you are going to do any significant plow/cultivation work.
While most current actual ag utility tractors (NH TNs, JD 5000's etc.,) include draft control standard, very few CUTs offer draft control (generally just the largest CUTs). FNH has it standard on the TC48/55 models. Deere used to offer it as an option to the 4510-4710 but appears to have dropped in with the 4000 Twenty series.
Hi Jay, I tried all the way down , as well as reverse. It baked out with no problem.
   / 1st day on CK25HST,,,impressions #14
If you were pressing the pedal all the way down, that may have been the problem. If you are ever in that ditch again, press slightly on the hydro pedal. /forums/images/graemlins/wink.gif
   / 1st day on CK25HST,,,impressions #15
Hey Cliff -
I used the brake-turn feature while working in the wooded part of my rear lot. I've got a lot of trees to work around (for now - their days are numbered /forums/images/graemlins/smirk.gif) the brake turn is real useful in these super tight quarters. And like yours - my brakes are on the left and the go pedals on the right... I'm surprised this isn't a universal constant.
   / 1st day on CK25HST,,,impressions #16
Glad to hear your enjoying the tractor - What kind of mowing are you using it for? Right now I think I have way too many trees in the yard to even consider using a MMM or RMM in my yard... sure wish I could though.
2020 Ford F250 Pickup Truck (A55973)
2020 Ford F250...
Rooster Weathervane (A55853)
Rooster...
2018 Ram 3500 Chipper (A55973)
2018 Ram 3500...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2006 Wells Cargo 16ft T/A Enclosed Cargo Trailer (A55973)
2006 Wells Cargo...
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
