1998 NH 1925??
   / 1998 NH 1925?? #1
dogdrool
Busseyville, WI
1988 Ford 1710, 4x4, FEL
A dealer close by has a 1998 NH 1925. 900 hours. Asking $12,800. The tractor is currently on Tractorhouse. What do you guys think of the tractor and model? I know NH only made them for 2 or 3 years. I'm shopping for my first compact tractor and can use all the help i can get.
   / 1998 NH 1925?? #2
I've got the 2000 NH 1920 as my first tractor, which I think is the same tractor without hydrostatic drive, and I have been extremely happy with it. Things to check: clutch (had to replace mine at 700 hours, previous owner 'rode' the clutch and wore it out), seals on the front 4WD axle, wiring and safety switch condition (had numerous problems with aged wiring harness), hydraulic pressure and hoses and 3 point hitch movement, crankcase oil (of course), color and condition and level of hydraulic fluid. The engine should crank easily with sufficient voltage to the starter. I am not a big fan of hydrostatic drives so I cannot comment on that but they can be problematic in unkept and aged condition. Hope this helps and good luck.
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2017 PETERBILT 567...
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
