1998 4200 lug pattern
/ 1998 4200 lug pattern #1
RoMad
Platinum Member
Lecanto Florida
Kubota L3710
I have a friend with a 98 4200 and he needs to know the lug pattern for the rear wheels. He is looking at getting another set of tires and wheels but is not sure as to the lug pattern. Anyone know?
/ 1998 4200 lug pattern #2
He can remove two bolts diametrically opposed for the bolt circle diameter, then count the number of bolts (should be 6). May as well measure the bolt hole diameter while he's at it.
That will give him all the information he needs...
Thanks, I will tell him. Actually he will probably read it himself. He had never heard of this forum before today.
/ 1998 4200 lug pattern #4
If he wants a pattern, hold a paper plate over the lugs and tap each lug with a rubber mallet.
/ 1998 4200 lug pattern #5
Yeah...but then he'd have to remove all the bolts.
/ 1998 4200 lug pattern #6
why can't you just run a tape measure from one bolt head to the one across from it. You will get darn close, close enough to figure out the pattern. I always just eyeball center to center, and you have a pretty good idea what you have then.
I would have to guess its a 6 on 6" bolt pattern, there aren't that many choices of six lug patterns.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2297 (A64281)
2297 (A64281)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
