1996 NH 3430
   / 1996 NH 3430 #1
beernuts
Illinois
AC WD, NH 1520 TLB, NH1920TLB, 1973MF135 , 1967MF 135 and 2135, 1996NH3430
Hello all, needing advise. I bought the 3430 not knowing a great deal about it and only researching it for less than a day, some of the research on here (love this place). The previous owner was a nursery that ordered this thing new. I got the manuals and maint. Log for the machine. In the last month it got a new injection pump, new injectors, a new starter and ignition switch, all dealer installed with receipts for over 3k. Upon starting the tractor, it presented with a knock that was a spun front main according to the dealership's diagnosis. I have not torn it down to confirm as of yet. The tractor was in great shape otherwise, sheet metal etc. I don't know but suspect it was caused by an oiling issue. The nursery ordered this thing with dual remotes and the creeper gear set that gives 4 more speeds that are less than 1 mph. According to the maintenance guy at the nursery, it mainly tugged a gang of wagons and the 3 point was not used. I have never owned a tractor with IPTO before so I am curious if I will like it. There was only one review on the tractor out there but it was a good one, what do you guys think? I paid $1500.00 for the thing as it was sitting with 2400hrs on the meter that evidently worked according to the service logs and the dealership. I hope that the block is salvageable with a line bore and a new crankshaft etc. I will likely go through the whole engine with a major kit and have the head work done too. I don't know what to think on the parent bore engine, the Perkins 152 diesels I have dealt with in the past were sleeved and simple/cheap to rebuild. This seems like a lot more/refined tractor than the 135s I have owned in the past. Does the 192 Ford run as well as the 152 Perkins?
I want to know, rebuild it or buy a short block? Alexander's in TX has them for 1795.00, has anyone ever dealt with them? Was curious if they were reputable. I called them, they said they did all of Thier own machining in-house. Or if anyone else has any suggestions on a reputable reman shop that is reasonable.
Eric
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2017 Ford F-150 Ext. Cab Pickup Truck (A55973)
2017 Ford F-150...
