Price Check 1996 NH 3430
   / 1996 NH 3430 #1
beernuts
Illinois
AC WD, NH 1520 TLB, NH1920TLB, 1973MF135 , 1967MF 135 and 2135, 1996NH3430
Hello all, been awhile since I have been on here. I have went through some tractors since I was last on here. I got rid of my 1520 and a 1920 NH and a couple of MF135s that I had. I still have my old AC and a project 2135 that I picked up for near nothing that I am working on and the recently acquired NH 3430. I bought the 3430 not knowing a great deal about it and only researching it for less than a day, some of the research on here (love this place). The previous owner was a nursery that ordered this thing new. I got the manuals and maint. Log for the machine. In the last month it got a new injection pump, new injectors, a new starter and ignition switch, all dealer installed with receipts for over 3k. Upon starting the tractor, it presented with a knock that was a spun front main according to the dealership's diagnosis. I have not torn it down to confirm as of yet. The tractor was in great shape otherwise, sheet metal etc. I don't know but suspect it was caused by an oiling issue. The nursery ordered this thing with dual remotes and the creeper gear set that gives 4 more speeds that are less than 1 mph. According to the maintenance guy at the nursery, it mainly tugged a gang of wagons and the 3 point was not used. I have never owned a tractor with IPTO before so I am curious if I will like it. There was only one review on the tractor out there but it was a good one, what do you guys think? I paid $1500.00 for the thing as it was sitting with 2400hrs on the meter that evidently worked according to the service logs and the dealership. I hope that the block is salvageable with a line bore and a new crankshaft etc. I will likely go through the whole engine with a major kit and have the head work done too. I don't know what to think on the parent bore engine, the Perkins 152 diesels I have dealt with in the past were sleeved and simple/cheap to rebuild. This seems like a lot more/refined tractor than the 135s I have owned in the past. Does the 192 Ford run as well as the 152 Perkins? I got away from the 1920/1520 because parts were stupid expensive and I was afraid that I would reduce one to a paperweight if it were to break. They both proved to be good tractors just smallish. Well give more your thoughts....good tractor and did I get hurt? image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
   / 1996 NH 3430
Sorry looks like I posted duplicate pics, dang ipad, I know it's not the operator. I was hoping to hear from Rick B or Soundguy (no particular order) on this as they seem to be gurus on Ford/NH.
Thanks
   / 1996 NH 3430 #3
The 192 is a good engine, it was used in several of the Ford tractors. The parent bore engine is not a major problem, however if it needs over bored then the cost shoots up. The parts are reasonable with a complete over haul kit with valves running under $700 from tractorpartsasap.com. The major cost will be the machining. The labor for the head will be around $200, to grind the crank it will be another $200. I do not know what the cost to bore out the block would be but a fair bit I would imagine. If you have the dealer do the disassemble and reassembly of the engine then it will cost a considerable bit more.
The parts are much more affordable than the Shibaura compacts, however you still have some major work that needs done to it.
2001 Genie S-60 Manlift (A57453)
2001 Genie S-60...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
Squat Machine (A57454)
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
