1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #1
Jeffintheburg
Gaithersburg, MD
JD 445
My father in law called from his RV out on the road and said that the crankcase breather tube has begun dumping about 2 quarts of oil out every 100 miles. He said that it still has lots of power and sounds like it is running good.
We were wondering if he may have cracked a piston or ring. Not sure what would cause the sudden change in oil blow by.
Thought I would check if any of you have any ideas what to look for.
Appreciate your thoughts.
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #2
I have a '96 Cummins as well. I'd assume that it should be something fairly simple since I've never heard of anyone blowing a '96 12 valve Cummins model yet unless it has been subject to severe abuse and no maintenance. Go here http://www.dieseltruckresource.com/dev/forumdisplay.php?s=&forumid=100
and post the question. You will have answers within the hour. Good luck!
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #3
Best take it to a certified repaire spot and let them tell the tale.
Egon
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #4
NOT A DODGE DEALER, NOT A DODGE DEALER, NOT A DODGE DEALER!!!
Take it to a Cummins Engine repair station, a "big truck" service depot. Dodge dealers will only screw it up further! I would imagine it is something simple.
Where does he get the truck serviced? Is there a possibility that it was over-filled with oil? If it was, this is where the oil will be spat out.
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #5
</font><font color="blue" class="small">( NOT A DODGE DEALER, NOT A DODGE DEALER, NOT A DODGE DEALER!!! )</font>
I surely agree with that. Some dealers will have competant staff but Cumins is a better bet. /forums/images/graemlins/grin.gif
Egon
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #6
I took the liberty of posting your question on THE Cummins Diesel website. Turbodieselregister.com I'm sure the guys there will have some thoughts. Will forward the responses to you
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #7
I think this truck still has vacuum assisted brakes and if the vacuum pump hose splits (the hose runs from the vacuum pump (just in front of the power steering pump) to the brake booster (the big pancake thing behind where you add brake fluid) you can have blowby.
A turbo seal failure can cause blowby also.
I'll agree that it needs to go see a cummins dealer, there are too many simple and inexpensive things that could be wrong to let somebody unfamiliar with diesel engines loose on it.
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #8
The hoze should be covered by a recall.
Egon
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #9
I think this guy has some blow by with his '96... /forums/images/graemlins/grin.gif
   / 1996 Cummins Turbo Diesel 5.9 Oil Breather Blow By #10
Don't you get it Dargo...Get a powerchoke and all your problems are sloved? Don't you get it! Rotella and Powerchoke are GOLD, GOLD I say! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
UNUSED 78" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED 78" HYD...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
