1996 cat 426b hydraulic pump vibration issue. (With video)
   / 1996 cat 426b hydraulic pump vibration issue. (With video) #1
Alexp08
cumberland, MD
none
Hello, can anyone point me in a direction as to why my hydraulic pump is vibrating out of control?
Link to YouTube is the video. First few seconds are regular speed then it cuts to slow motion for the rest of the video. Thanks.
1996 cat 426b hydraulic pump vibration - YouTube
   / 1996 cat 426b hydraulic pump vibration issue. (With video) #2
Looks like the drive flange on the front of the crank is lose, cloud have a couple broken bolts and has turned off center.
   / 1996 cat 426b hydraulic pump vibration issue. (With video) #3
Could you give the machine number prefix? It should be in the form of 8RF or something. You have a 17 digit PIN but the important ones are the last 8. I don't want the last 5 - they identify your machine. There are, however, several 426B's and I can't look up the right service info without the 3 characters/digits that identify which real model and which plant it came from. Your vintage should have a Tier 1 3054 engine, on my machines we ran the hydraulic pump off the engine front gear train (valves, water pump, injection pump and in our case hydraulic pump). For your BHL, however, that gear train is not substantial enough to power the larger higher pressure hydraulic pump so they created an adapter to drive from the crank pulley. I believe the other person is correct - something sheared in there; however, the adapter hub may pilot in the crank pulley so it may have broke something there. I'd like to look through my service info on your particular model.
I hope it was just a bolt, I'd hate for something yo habe gone wrong with the crankshaft.
I believe the number you're asking for is "6KL"
I appreciate all the help!
   / 1996 cat 426b hydraulic pump vibration issue. (With video) #5
You can see from this frame I took, the pulley on the pump is coming away from the other pulley. Look at the difference in spaces. Check for loose or broken bolts and nuts.
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Hydraulic Dovetail Trailer (A51692)
2007 Trail-Eze...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
2017 FREIGHTLINER M2 - 26' BOX TRUCK (A51247)
2017 FREIGHTLINER...
