1996 873 bobcat parts
   / 1996 873 bobcat parts #1
htatro
I just purchased a 1996 873 bobcat that has some fire damage. Were would be a good place to get parts for this? Is there any salvage yards out there? I know that I'm going to need a fuel tank, oil tank, and some of the wiring harness.
   / 1996 873 bobcat parts #2
The 1996 model is pretty close to the first 873s ever produced... so it may be difficult to get certain parts for that loader if a lot was changed (I'm not sure). Your best bet would probably be a Bobcat dealer parts department, or just go ahead and buy a used 873. (I say that because getting to the fuel tank requires pulling out the engine, I believe.)
Well I know that the wiring harness from bobcat will run about $3,000 or so and the fuel tank and oil tank would be about $300. I know that I need that for sure. I'm trying to decide if I should try and fix it or just sell it as parts. It was basicly given to me so I have no money in it as of now. I might try and ebay it and see what happens. I was hoping that there might be a Bobcat salvage yard out there. I havn't had any luck so far.
Thanks,
Andy
   / 1996 873 bobcat parts #4
I have a 873 that i need some parts also,plus my freind needs some parts for his 873 mine is a 1998 his is a 1999 if you found a place to buy used parts for this machine please contact me or if you decided to part your machine out please contact me thank you al
   / 1996 873 bobcat parts #6
hi im wonderin if you might be parting this bobcat out if so i need the shaft that moves the wheels let me know thanks
   / 1996 873 bobcat parts #7
Did you have any success finding a bobcat salvage yard? I have a 743 that I purchased without an engine, and I am having a real hard time finding an engine. it seems like no one is wrecking bobcats out there,
Thanks,
Chuck
   / 1996 873 bobcat parts #8
Im trying to find a manual for a wiring diagram i keep having a problem with the lights and cant figure out which wire is which. All the new plugs from bobcat are different than the old
2016 Ford F-550 Enclosed Service Truck (A51692)
2016 Ford F-550...
SYSTEM ONE 102 DEGREES PARTS WASHER (A51248)
SYSTEM ONE 102...
2025 Swict 72in Bucket Skid Steer Attachment (A51691)
2025 Swict 72in...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2019 KOMATSU D51PXi-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
