1995 LK3054 PTO question - New Owner
   / 1995 LK3054 PTO question - New Owner #1
fishbones
Michigan
Kioti LK3054
I just picked up a 95 Lk3054 with 504 hours from a local dealer last Thursday.
It has a 2 speed rear PTO, 540 is down, N, 1000 is up.
The neutral position is a little above N but not bad, it goes into 1000 good and there is about a 1.25" space between N and 1000.
Problem I noticed was going down from N into 540, there is only about a 1/2" drop to go into gear and its a little tougher than it should be but goes into gear.
When in 540 the shift arm is just below N. This is strange, why its not going all the way down to 540.
Anyone ever seen this before?
   / 1995 LK3054 PTO question - New Owner #2
I don't believe this makes any difference so long as it shifts into either range. There is no linkage adjustment on the shifter so what you got is what you got. I have never noticed whether mine is like yours, but will check the next time I'm around the tractor
Thanks Patches,
I have no idea if this is normal or something to be concerned about.
I appreciate you checking yours out.
   / 1995 LK3054 PTO question - New Owner #4
I had an opportunity to check the lever throw on the PTO; they seem to be equally distant from the neutral gate, but the 540 range has a "hitch" in it, that is, it shifts to the 540 range, but then the lever continues downward for another 1/2 inch or so after it feels like a completed shift. I didn't start the tractor, so am unsure whether the initial shift to the "hitch" is sufficient to engage the 540 range; can check that later if it would help any
Thanks for the info patches.
I am going to try and adjust the shift arm so Neutral is center and see how it goes.
I called the dealer today and they dont seem to worried about it but it just dont seem right to me.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
New/Unused 66in Quick Attach Rock Bucket (A51573)
New/Unused 66in...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
