1995 Jinma 204 Hyro fluid in the engine crankcase
   / 1995 Jinma 204 Hyro fluid in the engine crankcase #1
Crispy80
Jinma 204
New to the forum, but pretty sure after reading thread 2 below that the hydraulic oil is making it into the engine crankcase. (Back story) The bucket and steering was operating fine, but the hitch was not moving. I noticed the hydraulic fluid in the back end of the tractor was not even touching the dipstick. I added about 3L of fluid which did not even bring it up to the low level. I remembered the 'lowering speed adjustment valve' knob between my knees (when sitting in the seat) and opened that way up.. and it operated fine.
Days later I checked the crankcase oil and it was coming out of the dipstick hole. After seeing this high level of oil I drained it.. and turns out to be 3L.. (similar level to what I had added).
I have run the tractor for about an hour after removing the 3L of fluid from the crankcase, and all the hydraulics work fine. my concern is that if I want to top up the hydraulic again it will dump into the crankcase. Or over time it will leak back to the engine
I see the member Affordable always seems to have the answer. Is the hydraulic fluid getting into the engine through the hydraulic pump? Is this a rebuild or a replacement? Also I am in Canada, can I get these parts here or can they be shipped from the US?
Any help would be great!
post 2
3rd post required to put links in.
   / 1995 Jinma 204 Hyro fluid in the engine crankcase #5
A common pump failure is for the main seal on its shaft leaking and the hydraulic oil enters the crankcase.
I do not believe just filling the hydraulic reservoir will lead to hydraulic oil in the engine unless it is entering by way of the main seal on the pump drive.
I have been surprised in the past about the low cost of hydraulic pumps on some Chinese tractors and getting a complete pump is likely the most practical fix.
Look at the attached screen shot from an American site. A complete pump for $231.
When I Google Jinma Canada I end up with this place for parts.
Jinma Tractor Parts | ASIAN TRACTOR PARTS
Dave M7040
   / 1995 Jinma 204 Hyro fluid in the engine crankcase #6
About 15 years ago I had a Kubota B7200 that started dumping hydraulic oil into the crankcase and replaced the seal on the hydraulic pump and it was ok for a while but soon started again. I replaced the pump and that took care of the problem. It was a little pricey but you gotta do what you gotta do.
   / 1995 Jinma 204 Hyro fluid in the engine crankcase #7
One thing I'd do right away is drain the crankcase fully and refill with motor oil. Hydraulic oil and engines don't get along well.
   / 1995 Jinma 204 Hyro fluid in the engine crankcase #8
I'd just park the tractor. Hydraulic fluid will dilute the engine oil and cause damage.
A overfilled engine crankcase can also cause damage.
I 100% agree on changing the engine oil. I've attached some pictures (hoping this works) Can someone confirm that this is a CBN-E310 RH Pump.
I have also read when you remove this pump there are 4 bolts, but you want to remove the 2 large bolts first which connects it to the engine. which are these 2 bolts as mine appear to be the same size? What are peoples thoughts on rebuilding the pump?
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
1987 FRUEHAUF 8,000 GAL TRAILER (A53843)
1987 FRUEHAUF...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
