1995 Ford 5610S tractor
/ 1995 Ford 5610S tractor #1
ozarkpreacher
Morrow, Arkansas
1995 Ford 5610S 2 wheel, diesel
I am having a problem with the gauges and horn working. The lights work on the gauge just fine but the fuel, tach, oil pressure, and battery light are inoperative. Before a freeze last winter everything was working fine. I have checked the fuses and they are good. I have an owners manual but it does not contain an electrical diagram of the tractor or I could figure it out quickly myself. any suggestions?
/ 1995 Ford 5610S tractor #2
:welcome:
Sounds like you may have loose or corroded ground connections.
OK. Thanks. I was kind of thinking the same thing. The ground contact would all have to be one the same wire and differebt from the lights so guess I will just have to pull the Gauge panel out enough to find where the ground wire is and follow it to both ends. Thank you for your post Bigfoot62.
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2016 CHEVROLET SILVERADO 2500HD (A67714)
2016 CHEVROLET...
2026 Unused CID ITAKB72-SC 72in. Skid Steer Bucket Attachment (A66734)
2026 Unused CID...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2012 . Tri Axle Crude Trailer (A67714)
2012 . Tri Axle...
