1993 JD 445 won't start - no spark
   / 1993 JD 445 won't start - no spark #1
rocksoldier
1993 John Deere 445
Hi there,
I have a 1993 JD 445 (sn M00445A011748). Fuel injected. I'm not getting a spark so it's not starting. I've had the machine for over 15 years and did most of the maintenance myself. The machine started fine a few days ago to cut grass for 5 minutes. It has always been shedded.
Here is some info:
-I bypassed the seat switch so that is likely not it, but I did this in my troubleshooting so am not 100% sure.
-Lights on dash are normal and strong. Headlights work too.
-red and green lights on PCB go on when I press the brake (need to push the brake to start it).
-both spark plugs are not sparking. I put in new plugs and same thing.
-I put in a new air cleaner.
-I have always used premium gas, but it is a 1993 and I have never used fuel stabilizer.
-When I try to start it with plugs in or out, it makes a steady sound, not a hum but not super loud either, like it's trying to start but can't since there is no spark.
-PTO switch is fine because it kills the ignition process sooner.
-In my multiple attempts to start it during my troubleshooting, it did backfire twice.
-I think the fuses are good because I get nothing when I turn the key with one fuse out.
   / 1993 JD 445 won't start - no spark #2
:welcome: to TBN
Have you read the "Similar Threads" identified at the bottom of this thread? Looks like 4-5 of them that could be related.
Keep us posted on what you find out. Hopefully something simple, just need to locate it.
How many hours are on the 445?
   / 1993 JD 445 won't start - no spark #3
Ran into that issue with a customers mower a few years. Found that one of the fuses wasn't making contact.
   / 1993 JD 445 won't start - no spark #4
here's the same problem. read past the incorrect info for the correct info, but hope you don't have a bad control module, which goes for $928!!!.
no spark on 445 JD
Thanks for your help. It turns out it was the camshaft.
   / 1993 JD 445 won't start - no spark #6
Tell us about "it was the camshaft". Must be a story behind the OP question and your finding "it was the camshaft".
Think we'd like to hear more, and your info will add to the archives of TBN on JD 445's.
   / 1993 JD 445 won't start - no spark #7
Yes same here. I will be interested in knowing how a bad cam will cause no spark.
Richard
   / 1993 JD 445 won't start - no spark #8
I do believe you meant the crankshaft reluctor ring, or the magnetic sensor.. instead of on the crankshaft, these might be placed under the flywheel..
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
1994 HEIL BULK TANK TRAILER (A59575)
1994 HEIL BULK...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2012 John Deere 6170R (A57148)
2012 John Deere...
2023 FORD F-150 XL TRUCK (A59823)
2023 FORD F-150 XL...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
