1992 john deere 425
/ 1992 john deere 425 #1
Loganjohndeere425
92 John deere 425
Started her up this afternoon heard a snap and lost compression on the right cylinder. Pulled the valve cover and rockers aren't moving but left side has loads of compression? What could be the cause??
/ 1992 john deere 425 #2
Plastic cam gears are a known failure point on certain years and models of the Kawasaki engines used in Deeres. Hopefully that snap wasn't piston hitting a valve.
/ 1992 john deere 425 #3
My JD 285 had the plastic cam gear fail. It was when starting the engine (engine failed to start). Mine lost 7 teeth in row on the plastic cam gear, so the cam was no longer rotating when I cranked the engine. IIRC these engines are ones the valves do not hit the pistons.
217982 (A65054)
217982 (A65054)
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
Unused 2022 Land Pride QH30 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2022 Land...
