1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever
   / 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever #1
buildinit
Rusk, Wi
John Deere 955
I have a 1991 John Deere 955 with just over 3200 hours. It just recently developed a diesel fuel leak on the top of the motor near the rearward "glow plug/injector/bolt cap looking thing with fuel line going into it" area. I don't have the motor tech manual so I cannot tell you exactly what part it is.
I filled it with fuel yesterday and may have spilled on top of the motor. But I started it and ran it for a good thirty minutes yesterday after fuel up, and cleaned up the fuel off the floor and re-parked it. The fuel did not dry off the top of the motor during that 30 minute run, the motor seemed very cool; it was like 15 degrees yesterday. Today I go out there and there is a small puddle of fuel on the floor and that area on top of the motor still looks wet. It's not engine oil; it's absolutely diesel. Anyone have this issue before? I picked up some engine degreaser and carb cleaner to try and determine if there is a source to the leak.
Also, I cannot get the e-brake to engage, any advice? I greased the pedals and all points as per the manual.
Also, my actuator linkage for the FEL needs replacing as well as the oins. Any advice.
Thanks a ton.
Luke
Re: 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake leve
I found out that the rubber fuel line is dry rotted and slowly dripping. Still have not figured out the e-brake!
   / 1991 Deere 955 - leaking fuel on top of motor - unknown location - & e-brake lever #3
e-brake... meaning the Park Brake ?
rubber fuel line... are you replacing this?
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
