1990's GM 6.5 Turbo Diesel???
   / 1990's GM 6.5 Turbo Diesel???
L39Builder said:
That's good advice. Currently, I run a 7.3L Powerstroke and a 6.6L DMAX and I think they're bother great diesels. However, the DMAX is MUCH more refined & quiet. The 7.3L is a clatterbox. Make sure you find cab noise with the 7.3L acceptable before you buy. I can barely hear my cell phone in mine. My DMAX is so quiet inside it sounds like a gas engine truck with a nice soft turbo whistle.
The transmissions are really what you should be looking at. IMO, only GM has built a transmission worth putting behind a diesel engine, the allison 1000. It's a really sweet transmission. The Ford trans is OK, but it will eventually fail behind a 7.3L if you want to tow with it. The older Ford trans (4R100) is a failure waiting to happen. A 6-speed would last much longer.
The newer Ford Torqshift ('03 & newer) is a step in the right direction, but it's no allison.
(Quote)
Thanks for all the info. In my price range, I am definetly confined to an older truck. I heard the major fault with the Ford automatic tranny is from towing in OD. That goes for even the gas powered trucks. My friend has a DuraMax/Allison and it is quiet as can be compared to my neighbors 7.3L. As a matter of fact his DuraMax is as quiet as my old 81 Olds Delta 88 Brougham diesel was.
L39Builder said:
your best bet would be a Ford 7.3 or Dodge 5.9 with a manual trans. Very reliable, economical & real easy to maintain.
The search continues for a nice cheap diesel truck.
   / 1990's GM 6.5 Turbo Diesel??? #14
Nice...cheap...diesel.
Pick two; you can't have all three.
Seriously, why a diesel? You don't put very many miles on one, I think you'd probably be happier later if you didn't buy a well-used diesel now.
Diesel up here is cheaper than gas. They get better mileage when towing. I get about 8 mpg when I haul my boat. A round trip to L.I. Sound cost me about $65.00 using my pickup. My Ford is a gas guzzling POS as far as I am concerned when you put it under a load. It will get 14 mpg on the highway if you keep it at 65 mph or under when empty. Add weight and watch the gas go right through it. I also need something that can be used to plow with, carry rocks, cord wood, lumber, plywood, sheetrock and whatever else I want or need to pick up. If I was rich I might consider a foreign pickup and a dump trailer. I hear they haul pretty good.
   / 1990's GM 6.5 Turbo Diesel??? #16
In just over two years I have only put about 10K on my Ford pickup.
You need to do some number crunching to figure out where the break-even point is going to be if you go with a diesel. That few of miles is not what a diesel is meant to do. A 15mpg diesel vs an 8mpg gasser, over 5,000 miles in a year, will save you $93 per month in fuel costs, based on today's prices (unleaded @ $3.40, diesel @ $2.80). A single repair on the diesel will wipe out all those savings, for many months. Everything you touch on a diesel costs much more than a gasser. Dual batteries, turbos, injectors, injection pumps, 14 quart oil changes...it goes on and on. There is nothing economical about these trucks--they are only less expensive to operate when compared to gas trucks that are being used hard every day, lots of miles over a long period of time.
Plus, I don't think this disparity in fuel prices is going to last. I hope it does, but have my doubts.
   / 1990's GM 6.5 Turbo Diesel??? #17
The fuel price difference is cycical in my experience. The gassers cry all summer, I cry all winter when heating oil season starts.
Last year for example, road diesel was around $2.63 most of the summer. Started getting cool and it jumped over $3.00. Got to $3.15ish at one point.
Warm again and it's $2.79.
I was halfway looking for a TDI VW fuel miser to ride around in and keep the miles down on my F350 till I hit a deer last week. Rethinking the fuel savings vs deer damage to small car. Deer are quite numerous here. YMMV.
Fortunately for me I do all my own repair work. So the cost to fix anything is a parts only cost. I have a motorcycle and a car available for doing all of my errands and running around. The truck is for heavy jobs only and plowing. I know about the gas cycles and how the oil companies inflate prices each summer to screw us, and how they inflate heating oil in the winter to screw us again. I guess I could compare my 27 horsepower 7275 Cub Cadet diesel tractor against the old, I think 28 Horsepower, 1952 Ford 8N gas job I used to own. The little Cub Cadet runs circles around what the 8N could do.
   / 1990's GM 6.5 Turbo Diesel??? #20
I would agree if he was buying a new truck, but if he's buying a used truck with many miles on it, I would think the gas engine would be close to shot whereas a diesel engine could easily go 300-400,000 miles before needing to be replaced.
Gas engines don't last as long and need repairs, too.
The older "90's" 7.3L & 5.9L were models of simplicity & very economical to maintain.
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2020 KENWORTH T880 ROLL OFF (A52141)
2020 KENWORTH T880...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
