Backhoe 1989 john deer 750 backhoe question
   / 1989 john deer 750 backhoe question #1
proudpapa1985
i was going to get a 3pt bh but it weighs 1150 lb will it be to heave for it
   / 1989 john deer 750 backhoe question #2
I don,t know what the exact 3PH rateing was on a 750,but on 770 it is only rated at 815 lbs 24 inches beyond lift pins.Since most the BH is farther out than 24 inches,I would say ya thats to heavy for a 750.
   / 1989 john deer 750 backhoe question #3
When I bought my Woods 750 Backhoe, it was mounted on a JD 770. The previous owner had used it for trenching septic tanks, leach beds, and footers as a full time business. He didn't have a sub frame kit on the hoe, but did some beefing up on the 3 pt hitch (stabilizers). I use the same hoe on my JD 4500, according to JD info, the hoe is the next size smaller than what is recommended for the tractor.
Good Luck.
ok that helped thank you
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
Mini Excavator (A55787)
Mini Excavator...
