1988 John Deere 420 with PTO/Electrical Problem
   / 1988 John Deere 420 with PTO/Electrical Problem #1
Tango2020
Sibley, MO
John Deere 420 and 3020
The battery light comes on after I mow for 20 or 30 minutes. The second I disengage the PTO the light goes off. If I keep mowing with the light on it eventually blows the 20amp fuse located behind the instrement panel and the engine dies. When I replace the fuse the engine will start again and run fine but the mower won't engage when I flip the PTO switch (although the PTO indicator light will illuminate with the switch on). IF I l let the tractor set and cool off we start the process over again. What could be causing this? I assume it's an electronic problem but my mechanic skills are basic at best. Should I change the time delay control module? From what I have read, it is rare for these to go bad. Are there other components I should check or replace? Thanks in advance....
   / 1988 John Deere 420 with PTO/Electrical Problem #2
When my exmark and my bolens did that it was time for a new PTO clutch. They are not cheap, but whadyah gonna do...............
I'm fairly convinced at this point that is the problem. Thanks for your reply!
   / 1988 John Deere 420 with PTO/Electrical Problem #4
The clutches on those need to be kept adjusted, the wider the gap the more current goes through the coil and the hotter it runs, used to be able to just get a new magnet, think the current draw should be around 6 amps or less.
David Kb7uns
Thanks David. How are those adjustments made? Is that something I can do or is it better done by the dealer?
   / 1988 John Deere 420 with PTO/Electrical Problem #6
I wasn't aware they were adjustable either??? Never heard of that. The clutch is simply an AC clutch like what's used on autos. Pretty sure your clutch is the problem. I'll be following this thread to hear the solution.
After changing several other less expensive electronic parts it turned out to be the coil.
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
378801 (A51572)
378801 (A51572)
