Buying Advice 1986 Mitsubishi BD2F dozer
   / 1986 Mitsubishi BD2F dozer #1
duke7595
S/W MO.
820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
Have a question, I'm considering buying a 1986 BD2F, the guy says it is "direct drive". Is this different from the standard version ? and is it
a good transmission ?
I have owned J.D.s dozers over the years, this would be the first Mitsubishi dozer for me. I don't know anything about them and was hoping you could
advise me before I commit to buying.
(1) Is the direct drive good or bad, ? I could really use some help on information about this machine. I checked the web. but could not find any useful information.
Would you give me your opinion if this is a good machine or something I should stay away from, Thanking you in advance.
   / 1986 Mitsubishi BD2F dozer #2
Have you run it??? Run it and see how you like it compared to the deere dozers you have had...
SR
No I haven't run it, it's located a far distance from me. I'm mainly trying to find out if they are any good, such as prone to problems.
   / 1986 Mitsubishi BD2F dozer #4
The reason I asked is, I "think" direct drive means it's gear drive tranny, as that's what Cat use to call their gear drive tranny dozer...
I believe all the small Japanese Cat dozers are still made by Mitsubishi, if that helps any?
I hope this helps some...
SR
I want to edit in, I just Bing.com that dozer and this came up...
Specifications for a Mitsubishi BD2F | eHow
Looks like I was right about the tranny...
SR
SR
Yes it does, and thank you for your help.
ASCO Transfer Switch (A52377)
ASCO Transfer...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
