1986 Ford 1710 4x4 w/loader
   / 1986 Ford 1710 4x4 w/loader #1
famagnelli
I am looking for a compact tractor for small horse farm maintenance and snow removal. I saw a 1986 Ford 1710 with a loader and 4x4 for $5850. It looks used and is for sale by an excavation company. What kind of questions should I be asking aside from the obvious like how many hours and how many owners?
   / 1986 Ford 1710 4x4 w/loader #2
Maintenance would be a good thing to ask about but you may or may not get a truthful answer.
You should be able to tell a lot by how it looks and how it feels when you try it out.
   / 1986 Ford 1710 4x4 w/loader #3
By the way, that sounds like a great price for that tractor with a FEL.
   / 1986 Ford 1710 4x4 w/loader #4
sale by an excavation company. This may be a good thing or a bad thing. was it over worked , doing jobs it was not intended to do? what shape is the rest of there equipment in? Do they service there own equipment the way they should?
   / 1986 Ford 1710 4x4 w/loader #5
Just bought two used tractors. Contractor used? Check clutch, employees like to ride clutch and wear out. Check trans and axle fluids. If foamy they have not been changed. Look in air cleaner, take it apart. Was it really serviced well. Check each brake separately. Have found home owners worse than contractors at servicing equipment. You never really know what you have till you get it home and spend lots of time checking. Good luck.
   / 1986 Ford 1710 4x4 w/loader #6
Just bought 1710 4WD w/ 770B loader and a grader blade. 1800 hours needs cosmetic work, lights, seat, small things. Tires near new all around. Hoses on loader will not last many years. Parked outside. $5500 in central Calif. Not well maintained by home owner on 5 acres with horses.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2023 New Holland C332 Two Speed Compact Track Loader Skid Steer (A49461)
2023 New Holland...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
