1983 snapper rear engine riding mower solenoid
   / 1983 snapper rear engine riding mower solenoid #1
mackross
Jackson SC
Snapper
I need to know how to connect the wiring to a three pole starter solenoid.
I don't know the model number of the mower, it is no longer on the mower.
   / 1983 snapper rear engine riding mower solenoid #2
If you have 2 big poles and 1 small. Battery to eather big pole and other big pole goes to starter. Small wire from switch goes to the small pole. Sometimes there is a red small wire that goes on the big battery pole, it feeds the switch and dash. Solenoid well be grounded when you bolt it down.
I also have a little wire that goes to the starter that goes on one of the big poles.
   / 1983 snapper rear engine riding mower solenoid #4
I don't know what that could be for. Should be battery into solenoid and a wire out to starter. I can't see why you have another wire from starter to solenoid big pole, what would that do? The 3rd wire (small) just turns the solenoid off and on.
After more examination that other little wire is black and red, and doesn't go to the starter but up under the flywheel. Apparently part of the ignition, but it connects somewhere on the solenoid, too.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
More info coming soon! (A53421)
More info coming...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
