1983 - Ford 2310 Hydraulics
   / 1983 - Ford 2310 Hydraulics #1
Highway312
Ford 2310
My hydraulic lift will not work at all. In the service manual, it lists the "flow control valve binding" as one of the items to check. I tried but cannot move the flow control selector valve.(The hand adjustment to make your hydraulic fast or slow) What/how should I proceed from here? How do I take it apart and what do I do to fix it?
Another question - Is their a recommended video, or manual that deals with hydraulics for this type of tractor? I see some for the 8n type but how about the newer ones?
Last question - Is it OK to put diesel fuel in a plastic gas can? This is my first diesel and I was wondering if the fuel reacts in any way to the plastic.
I'm done (for now) Thanks.
   / 1983 - Ford 2310 Hydraulics #2
<font color="blue"> Last question - Is it OK to put diesel fuel in a plastic gas can? This is my first diesel and I was wondering if the fuel reacts in any way to the plastic. </font>
Stop by your local Tractor Supply and pick up a yellow, plastic, 5 gallon container. No problems with storing diesel fuel.
   / 1983 - Ford 2310 Hydraulics #3
Yep.. black cans for oil, red for gas, yellow for deisel, and blue for kerosene... plastic is fine.
Soundguy
   / 1983 - Ford 2310 Hydraulics #4
</font><font color="blue" class="small">( Stop by your local Tractor Supply and pick up a yellow, plastic, 5 gallon container. )</font>
Walmart has them for less $.
Also, the one I got from TSC has a flexible filler neck that you push back into the can to close the lid. When you pull it out, it pulls fuel out with it that gets all over your hands. Walmart's have a solid filler neck that stays out of the can and is self-venting.
I started a thread a couple months ago about removing the smell of diesel from your hands. Bottom line advice from everyone: NOT getting it on there to begin with is easier than removing it /forums/images/graemlins/laugh.gif
Mark
   / 1983 - Ford 2310 Hydraulics #5
</font><font color="blue" class="small">( NOT getting it on there to begin with is easier than removing it
)</font>
Ditto. Even gojo / fast orange don't do justice at removing deisel or gas smell... I hate having that linger on my hands after working on the tractor...
Soundguy
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
City of Lakeland (A51691)
City of Lakeland...
REMLINGER 2300 LOT NUMBER 59 (A53084)
REMLINGER 2300 LOT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
