1981 Troybilt Horse....
   / 1981 Troybilt Horse....
If the adjustment block and roller are not worn, and the bushings in the shift mechanism are all in good shape, the factory belt should work perfectly. If any of those parts are worn you'll never get things right. A shorter belt is not the answer.
Tim
Thanks everyone for all the replies to my question. I'm happy to say the problem is solved. The spring had been jury rigged somewhere in the past and had way too much tension effectively locking the tiller in "go get it". After replacing it with the correct spring the tiller is operating perfectly. This forum is wonderful....
   / 1981 Troybilt Horse.... #12
I have a troybuilt horse from the late 79/early 8o's. My dad welded a square bar under the bottom of the handle to cure the bends. I have the original book that I use for reference. had the same problem played with the block and finally got it to work. Had to replace spring on the roller arm (broke/died of rust) did use a heavier one.
UNUSED SBC90 SANDBLASTER (A54757)
UNUSED SBC90...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
American G-Model Pump Jack (A55218)
American G-Model...
