1980 gehl 4500
   / 1980 gehl 4500 #11
To all with the intermittent starter problem on the Gehl 4500 and maybe many more, finally found the problem, The wires going to the starter solenoid from the switch is to small and if the battery is just slightly low the voltage drops to much to kick the starter al the way in, The solution is to install a starter solenoid down near the starter and run heavier wire from the battery to the new solenoid and then to the starter solenoid, then you can operate the new solenoid using the old wires from the switch because the new smaller solenoid don't use as many amps as the old starter does. Hope this helps. Bob
   / 1980 gehl 4500 #12
Not to diminish the information here, but want is this thread doing in Bobcat Tractor forum> or for that matter in Bobcat section at all. Bobcat is a brand name of construction equipment specializing in skid-loaders and mini-excavators that also had tractors for a few years. Gehl is another brand name that makes skid-steer loaders and other ag equipment but no tractors.
If thread was in Parts & Repairs it may get more notice and help others with similar problems.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2003 Big Tex 10PI...
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Caterpillar 6-cylinder Turbo Diesel Engine with Transmission (A55851)
Caterpillar...
