1979 Ford 1500 radiator isolation mounts - any alternative to New Holland P/N SBA398110050 ?
   / 1979 Ford 1500 radiator isolation mounts - any alternative to New Holland P/N SBA398110050 ? #1
yert33
1979 Ford 1500
Broke one of the rubber bobbin isolation mounts that go under the radiator. Any generic alternative to the New Holland P/N SBA398110050 ?
Or just bite the bullet and spend $31 for one? According to the NH parts drawing the studs are M8 x 1.25.
   / 1979 Ford 1500 radiator isolation mounts - any alternative to New Holland P/N SBA398110050 ? #2
I used a couple of rubber bushings and some through bolts when I needed to replace mine on my 1720. Not sure exactly how yours is set up but my Shibaura made Ford has several side brackets that require the radiator to be mounted close to the OEM height so if that applies just make sure your bushings are close in height
   / 1979 Ford 1500 radiator isolation mounts - any alternative to New Holland P/N SBA398110050 ? #3
Just go to auto parts store. Usually have a wall of odd things in help packages. Some packs have shock bushings in them. Or you may have some old shocks. Get those rubber bushings and use them.
Thanks for the ideas!
   / 1979 Ford 1500 radiator isolation mounts - any alternative to New Holland P/N SBA398110050 ? #5
if you get a carpet square, then you can cup off enough 2x2 square or what you need to make a set of Neoprene(rubber) vibration idolator. Can drill a hole in the middle to be bolted or tied off.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Electric Concrete Mixer (A51573)
Electric Concrete...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2001 Chevrolet Suburban (A51694)
2001 Chevrolet...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
