1978 JD 2130, adding rear remote
   / 1978 JD 2130, adding rear remote #1
Gloftoe
Austin, TX
None
I have the above listed tractor with a FEL, and would like to add a rear remote to it. Currently, the FEL's hydraulic hoses are connected to the tractor like this:
My question is, after purchasing a kit (valve, coupler, etc), how does it all connect up so I could have both my FEL and the new remote connected and working together? Are tee fittings applicable here, and I can just hook up to the existing in/out along with the FEL?
Any help is appreciated. Thanks in advance.
   / 1978 JD 2130, adding rear remote #2
You can connect scv pressure line with a "special tee" similar to photo below. Parts item 21 from JD is part # AW16707 @ $48.50 & item 13 is C19280 @ $24.91. It's probable that these same type parts are available from a good hyd fitting supply business.
   / 1978 JD 2130, adding rear remote #3
When I added a loader to my JD 2030 I bought the super expensive "tee" from my local JD dealer. A simple JIC 08 (1/2") run tee would have worked.
Current price is listed as $5.67 plus shipping
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
