1976 3600 draft control?
   / 1976 3600 draft control? #1
Onthesauk
NW Washington
Ford 3000
Anyone have a picture of the decal on the draft control of a 1976 3600? Neighbor bought one and decal has been painted over, not sure how to set it or lock it at different heights. Any help would be appreciated.
   / 1976 3600 draft control? #2
The little draft handle just has 2 settings, up and down.. Up should be position on that machine.. down should be draft..( pretty much true on all fords.. ) then use the 3pt lift lever for setting the 3pt lift height when in position control, or setting the draft sensitivity level when in draft control mode. ( all the way up on the 3pt lift lever when in draft will still raise the lift up as this is 'transport' mode.. etc.. )
Soundguy
Thanks Soundguy, will pass this on to him.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Electric Concrete Mixer (A51573)
Electric Concrete...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
