1975 International dually
   / 1975 International dually #1
CosmoAU
N. Alabama
L3830 GST
I wanted to see if anyone knew anything about these trucks.* I've been looking for a dually beater to work with.* It has a 392 V8, T427 4-speed, New Process 205 transfer case, Dana 70 front and international rears that are 4.87's.* Probably not a whole lot of them still around.* Waswanting to check the wealth of knowledge here and find out all I could.* Thanks in advance.
   / 1975 International dually #2
Don't know much about them but if International built it it'll be tough. They made a 1 1/2 ton pickup-sized dually truck in the early '70's that had 20" wheels. Only saw them with flatbeds, drove one several years ago and it really rode rough. The 392 was a good engine but drank gas, especially with that 4.87 axle ratio.
   / 1975 International dually #3
A Binder! I've had a few. 1975 was the last year for the pickup/Travelall trucks (and cab chassis sized similarly). Modest differences in the heads for smog engines (probably not a smog engine in Alabama). The engines were long lasting, nothing too special about them other than that. Everything ate gas then. Same engine would go into a 1600 or larger truck. In 74 they changed the model numbering scheme from the 900,1000, etc to 100, 150, 200, etc for the 1/2, 5/8, 3/4 class trucks (smaller than the large frame trucks. I presume this is the same for the 1300/1310 trucks (1 ton and under 2 ton).
You should find the line setting ticket (build ticket) behind the glove box (empty it out, then push in the limit tabs on the side of the door). It will be taped on the back of it. If it's not there, you can go to an IH dealer and they can run the VIN to print out a new one for you. But you already have the major info. The nice part with these trucks is that IH built them to work, not ride around and profile in (so no, they will not ride well when empty), and they used mostly standard components.
The only funny part is (as I recall) the stock electronic ignition came in two different colored brains (one gold, one black, IIRC). One was the better version. But they used Holley or another manufacturers distributor, so it's easy to change out to an MSD or other unit. The carb was (stock) either a Holley (the 'list number' is printed/stamped on the carb) or a Carter Thermoquad, so again, an easy fix. Some had conventional mount fan to water pumps, some had a coupling nut on the shaft. Most had a standard Delco alternator (but dual belt pulley). For those that haven't used them, you often can't get the dual pulley version in stock, so swapping them out is easy. Also, a store often doesn't have the correct 'clocking' (connector position relative to the mounting lugs). Also easy, you remove the 4 screws holding the two halves and rotate them to match the one being removed. If it has the Motorola alternator, you go find the Delco mounting brackets (or make some) then put it in on failure.
One thing about IH is that they often didn't release enough info to the rebuilders/ aftermarket. I had issues with getting a correctly rebuilt Delco starter for my 1974 392 (the starter had 4 field coils, but the rebuilders always cut the 4th ones lead -- made you have to click the starter several times to get it to work correctly). Don't know why.
The cabs tended to rust out in the vent boxes (outside edges of the windshield down to the top hinge of the doors) due to leaves getting in and plugging them.
The 266/304/345/392 v8's and the 152/196(304 & 392 divided in two) slant 4's share most components (slant 4 is literally a V8 with one cylinder bank missing, a new cam, and a new crank; a Scout only engine). 304/345 have the same bore, different strokes, 345/392, same stroke, different bore. 266/344, same block/stroke, just bored out (worth doing if you have a 266 at rebuild time).
Easy search on the web: Binder Bulletin - Powered by vBulletin, Binder Planet Forums. Even a couple of hop up articles.
Nice factory emblems -- a lot like the iron sites on a rifle. Another item that IH made once: 50's era M1 Garand's (and refrigerators, etc).
   / 1975 International dually #4
That's a REALLY rare find, very few pick-up types were made with duals.
The 392 should be a 4bbl Holley with a vacuum govornor, it defeatable but there for a reason. All the hardware is common industry stuff so replacements, if needed, should not be difficult to locate especially maintenance items. Sheet metal, that's a different story.
   / 1975 International dually #5
Tough trucks, can hardly tear them up. Similar engines were used in the medium duty range - 1-1/2 to 2 ton. Plenty of them used here in farm trucks and as irrigation engines on natural gas. The only drawback I see with an IHC built product will be parts availability and standardization. I spent 25 years in the parts industry and the IHC stuff can give you a few headaches in aquiring parts. Don't expect them to always be at hand, but may have to be ordered.
   / 1975 International dually #6
Never seen one of those in a dually that I recall. Sounds like one tough truck. As they say, if it's made by IH it's gonna be tough. Another thing IH made, of course, is the original Cub and Cub Cadet tractors. I have a late '60s IH Cub Cadet 122 garden tractor. Never seen anything that size built so tough! I always thought it would be fun to own a tough old IH truck, but somehow my Ford blood always gets the best of me. A friend of my dad's had a IH pickup for years. He kept it in beautiful condition. But parts have become a challenge. Today though, with the internet, seems like you can find just about anything.
   / 1975 International dually #7
We had TravelAll's back in the '70s that were very similar. Tough as nails and took the worst beating but kept on going. Only negative on them was turning. You didn't want to parallel park these suckers as the steering was 7 and 1/2 turns from lock to lock. You were all day turning to get it in a parking spot. Sure didn't do that much.
If it looks any good at all I'd go for it.
   / 1975 International dually #8
State (UofFl) had both pickups and flatbeds. Pickup had the 232-6 while the flatbed had a 345-8. Problem with ours was the flatbed was a crossover where some parts were earlier 1200 parts and later 1300 parts. Oh what fun that caused for brakes and such when you needed new parts. Engine never gave us any problems other than needing points about every two years. Gas, yep. The boss even ran it out of gas on a road trip. Didn't believe how little mileage and didn't fillup when told so he had to fetch.:D
   / 1975 International dually #9
Dad had a 72 scout two w/that v8 for a snow plow truck. When the electronic ignition went bad he went to an older distributor w/ points & condenser. It always started and ran after sitting for 6 - 8 months.
Rust got the body.
Every fall dad would open one door and empty a can of bee/wasp killer in and close it up...next day he'd hook on the battery charger & start clearing the mouse nests out of the air cleaner b/4 firing it up...IHC built some tough stuff!
   / 1975 International dually #10
One day long ago, I was sitting in a coffeeshop and happened to glance out the window to see the strangest Husker I ever saw go by. Yep! It was a genuine Hutterite Limo!:D
John Deere HPX615E Gator 4x4 Utility Cart (A51691)
John Deere HPX615E...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
2017 Kia Sedona LX SUV (A51694)
2017 Kia Sedona LX...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A53472)
2023 Maxx-D TDX...
2018 JOHN DEERE 317G SKID STEER (A51246)
2018 JOHN DEERE...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
