Comparison 1975 Ford 5000 vs JD 2030
/ 1975 Ford 5000 vs JD 2030 #1
Kando
Cromwell, Indiana
2xFord 5000, Ford 960
Hello TBN, I'm looking into these two tractors.
https://www.tractorhouse.com/listings/farm-equipment/for-sale/164218137/1975-ford-5000
https://www.tractorhouse.com/listings/farm-equipment/for-sale/190432579/john-deere-2030
The 5000 looks a little rough, but it has a cab and being a later model 5000, a better engine, at least on paper.
The 2030 looks about in perfect condition, only 1474 hours listed.
I have a 5000, so I'm already familiar with that particular tractor, operation and maintenance.
Majority of the work will be small square haying. Potential round baling if I come across a decent round baler that works well with 50-60 pto hp. Some tillage work as well, but not often. (Plowed a 16 acre field during the end of last year with my 5000, nice experience.)
Thoughts? How does the 2030 stack up? Prices are similar with the 5000 asking $500 more.
I'd noticed. Meant to add a "seem's too good" to that.
/ 1975 Ford 5000 vs JD 2030 #3
Look closely, the 2030 is a repaint.
And likely to have had the tach/hour meter replaced.
The Ford has two remotes, Dual Power, telescoping draft links and a crappy cab which could be replaced with fenders and maybe a ROPS and canopy for greater comfort. Without knowing any more about condition than what I can see I would pick the Ford. The cab is not desirable however.
HP would be very close. 15.5x38 tires on power adjust rims would be great for haying. A close inspection of both could tip the scale either way. The Ford is not likely to sit there long if it is sound.
I owned a 2030 once but it had a gas engine. I hated it but a diesel is far more desirable.
/ 1975 Ford 5000 vs JD 2030 #4
KANDO ???
Before you seriously consider either tractor, be absolutely certain that it's oil drain plug is EASILY removable.
KANDO ???
Well of course :D
Thanks for the input Rick. I've read a fair bit about the cabs on these older tractors being subpar. What about them is particularly problematic? I would probably keep it, if for no other reason than a bit more comfort against the cold winter wind while plowing snow.
/ 1975 Ford 5000 vs JD 2030 #6
I agree, the cab would be an asset in cold weather. And, it would be just as big of liability in warm weather. Since most haying is done in hot weather, I'd not put too much emphasis on the cab unless you could pair up with your open station 5000 and use whichever one applied.
I don't like to buy paint. Might not be anything wrong with the JD. But the price is where it's at partly due to paint.
I'd think the Ford would best fit your program.
/ 1975 Ford 5000 vs JD 2030 #7
I'm prone to the JD. Here's why: It has definitely been repainted and to that I say "so what". It is a stretch to say that because of that, the entire tractor is suspicious. You can also say someone cared enough about the tractor to take care of its appearance with a paint job because the rest of the tractor is so nice. Perhaps its previous and probably weathered paint didn't do it justice. Perhaps it looked like crap but didn't deserve to look that way. The Ford looks like crap and no one cared enough about it to do anything about that. They just wanted out of it.
Ok, you hay mostly. A canopy and a face mask abates the heat and particulates. Sit on the JD and run it. A tractor with only 1400 or so hrs will run like its just about new. No piston slap. No blow by. Explore parts availability. If they're equal, the JD gets the nod in my book.
As far as price. You can work on that. There is a premium to a low hr. tractor and that's the one I'd choose.
/ 1975 Ford 5000 vs JD 2030 #8
Kando, have you researched which one is less likely to have a stuck drain plug? :D
/ 1975 Ford 5000 vs JD 2030 #9
I'm gonna guess the Ford is "Farm Fresh".
I'm gonna guess the JD is "Trader Fresh".
/ 1975 Ford 5000 vs JD 2030 #10
I don’t think for one single second the Deere has 1400 hours on it. It is +/- 46 years old. If it were used 30 hours per year why repaint?
/ 1975 Ford 5000 vs JD 2030 #11
Agreed.
That's why I said "Trader Fresh".
/ 1975 Ford 5000 vs JD 2030 #12
I don稚 think for one single second the Deere has 1400 hours on it. It is +/- 46 years old. If it were used 30 hours per year why repaint?
You can think whatever you want. Doesn't necessarily mean a lick that it possesses actuality. Neither does mine. That is why we delve into matters.
To answer your questions. 1. Because of weathering for one. 2. Because it was worthy for a repaint for another because of its limited use. 3. How old it is, has little to do of how much it was used. Look at the hr numbers. The "1" is yellowed as if it's been sitting there awhile. I'd be more suspicious if that number looked fresh.
Its like finding that 1967 Mustang in a barn with 34,000 miles on it. It needed paint. The "why" of that is obvious. Perhaps this was found in a barn as well.
Before I shot something down with my own personal conjecture, I would want some back up to either refute or confirm a thought process. People buy things and then get sick or die. They might sell a home or farm and have little use for what they owned. There might be a divorce. There are a myriad of scenarios that lend to a situation. There could be a record of ownership if needed.
I do suppose it's easier to be simply doubtful however.
/ 1975 Ford 5000 vs JD 2030 #13
I think the John Deere hour clock is on its second rotation around . we had a 3130 that did the same
/ 1975 Ford 5000 vs JD 2030 #14
Before you start lording all over me go read post #3. And consider that the OP asked for our thoughts.
I’ve been buying and selling tractors and equipment off and on for many decades. Nothing replaces having hands and eyes on anything used. And a healthy dose of doubt and skepticism has served me very well. I’m not about to go look in person so I commented on what the photos show me. And I still highly doubt the hours are anywhere near correct. I also suspect the Deere is a European or Canadian spec tractor, but that is not certain by any means.
/ 1975 Ford 5000 vs JD 2030 #15
And your philosophy that it's a barn find 67 Mustang with 34K miles is also conjecture. And then,,,, if I found one,,,, I certainly wouldn't give it a $50 paint job.
Which do you think has more chance of being true? A barn find or "Trader Fresh"???
Think before you answer...… :D
/ 1975 Ford 5000 vs JD 2030 #16
Wasn't lording over anybody so get off that horse. I put both myself and you in the same "opinion folder". You have "healthy skepticism" that has served you well. What if your skepticism is not serving this person well? You came right out that this tractor was a falsehood with its hrs because of "skepticism". That is your opinion based on whatever. You cannot sit there and be positive that you are correct. Neither can I. I gave examples of possibilities that this tractor is legit. That is all.
/ 1975 Ford 5000 vs JD 2030 #17
Mine is not conjecture. I actually found a 1967 Shelby Mustang in 2001 within a barn in New Hampshire. It had a Paxton supercharger in it which was an option from Shelby at the time. This person was a friend of an uncle of mine there. The person was deceased and only the wife and a son survived him. My uncle told of this "Chevby car" for sale over his old friends house. I didn't know what he was sayin the car was so I said, "let's take a ride" since it was close by. You can imagine my surprise when this "Chevby" turned out to a "Shelby". I offered to buy the Mustang on the spot. The woman was in her 80's and she became reticent to part with the car as it was a memory of her husband. I told her no problem that if she sold it to me, she could keep it until her dying day.
She said she would think about it. In the weeks she was thinking about it, the son took it out to get new tires. In testing the "grippiness" of the new tires, he proceeded to wrap this car around a telephone pole. Because the car was simply insured as a 67 Mustang, it was deemed a total loss. If you ever come across a Brittany blue 67 Shelby Mustang that was nearly folded in half with a Paxton supercharger, it could be this one. More than likely it became a big ,metal square probably recycled into a 2004 Caprice.
I cannot make a judgement on "probabilities". I just know amazing stuff can happen. This tractor may or may not be an amazing find. No one here can say for certainty enough to bet your house on. The dash, shift knobs, seat could have all been replaced to help the tractor "look" like new or...they were never touched and the tractor is like new. A tractor with over 11,000 hrs on it should have "telltales" no? Things will be "worn" no matter if it were covered with paint.
Not let me ask a question or two. This tractor looks real fine on the outside. Would someone go to the trouble of putting in what looks to be a lot of work in replacement parts as well just to sell it? Or would they be more apt to simply dump it after a spray job and not care about the "intricacies" of a more detailed restoration that includes a seat, dash, knobs, foot pedals ,etc.??
I am doing no different (except an opposite opinion) of leaning toward the JD. I stand by my advice that the op should go over this tractor with some common sense and if he needs to call in someone to help him, he should do so. Due diligence is all I'm advising here.
/ 1975 Ford 5000 vs JD 2030 #18
Too bad you didn’t skip all the drama and just say that. Which is a lot like what I said as well, except favoring the Ford and calling out features and shortcomings to substantiate my OPINION. Nobody is suggesting the OP should buy either sight unseen.
/ 1975 Ford 5000 vs JD 2030 #19
"Drama"? You didn't like my story about the Shelby?
Are we helping the op yet?
/ 1975 Ford 5000 vs JD 2030 #20
Ask the dealer for the name of the previous owner. A reputable dealer would be happy to supply you with that info. You can then ask the previous owner about the hours.
