1973 Ford 4000 Voltage Regulator Issue
   / 1973 Ford 4000 Voltage Regulator Issue
The VR may have been just bad from the start. Or maybe it was polarized incorrectly when you put it in.
Voltage regulators are odd little beasts, A balance of mechanical spring tension versus electrically-generated magnetic force ends up with an old style voltage regulator. Which is a device which can literally be rebuilt at the kitchen table - or built from scratch in a home workshop. And not surprisingly, manufacturing them relies on some some care and craftsmanship winding coils and setting spring rates. That attention to detailed craftsmaship is going to be more and more unlikely as the demand for that old style voltage regulator diminishes.
Demand diminishes because voltage regulation devices for the past 40 or 50 years has been switching over to using semiconductor voltage regulation circuits. It is much simpler to consistently make a reiliable semiconductor voltage regulator - that's what all the modern alternators have built into the alternator. Of course that level of simplicity can only happen after technology has advanced to the point where semiconductors even exist. .... which takes a whole industrial base itself.
Be interesting to see what your voltmeter shows when you get a chance.
rScotty
Volt meter reading now in 14.8V to 15V range. Light staying off like is supposed to.
   / 1973 Ford 4000 Voltage Regulator Issue #22
As contacts wore they required adjustments. Had slots where a flat screwdriver could gently pry.
After few hours of use light started coming on again. Wound up taking back to repair shop. They determined new regulator failed. Replaced under warranty and back going again. Time will tell if this one lasts.
   / 1973 Ford 4000 Voltage Regulator Issue #25
Not surprised that you are having problems with modern replacements for old voltage regulators. The way the old solenoid/resistance VRs were designed doesn't lend itself well to today's cost-saving or "cheaper is better" type of manufacturing. This is a whole different era.
When you get tired of playing with that old generator/VR system check back in message 13 & 14 for another solution. Use the 3 wire type.
rScotty
   / 1973 Ford 4000 Voltage Regulator Issue #26
Yep, just put on a 3 wire 727 GM alternator. I did that on our 2003 Jinma. Worked perfectly after that till we got rid of it last year.
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
Steel Work Bench 24" x 60" w/6" Irwin Vise (NO CONTENTS) (A59076)
Steel Work Bench...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
