1972 ford 5000 hydraulic cylinder piston
   / 1972 ford 5000 hydraulic cylinder piston #1
tylertown
MS
Massey Ferguson 40 backhoe, Ford 5000 general purpose
I am putting new o-rings in my lift cover and I am not knowledge able enough to know if there is to much wear on the cylinder and piston to even fool with re installing it. Thanks pictures below
Any input is greatly appreciated.
   / 1972 ford 5000 hydraulic cylinder piston #2
You probably already did whatever you were going to but from what I read if you can feel it with your nail then it's going to leak. No direct experience but it's input.
I put it back together and it is very strong but it is bouncing so I'm thinking it's the cylinder leaking or the control valve spool or selector valve spool. It's aggravating but I have been working the tractor hard this fall prepping ground and it's doing fine just the 3 point hitch drops about 4in and bounces back up and it does it faster at higher rpm so definitely a leak...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2021 New Holland C327 Compact Track Loader (A53473)
2021 New Holland...
MachPro MP15Pro Mini Excavator, NEW! (A52384)
MachPro MP15Pro...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
