1970's IH 434 PTO shift oil seal
   / 1970's IH 434 PTO shift oil seal #1
bmorelectric
mississauga
harvester international 434
I hit a rock with my bush hog and broke the shear pin. The PTO shift attachment went flying around, then I noticed the PTO seal was leaking on the tractor and it looks like shaft has moved out (about 1/2 inch). Any thoughts how to get the shaft back in and replace the seal. Thanks in advance
   / 1970's IH 434 PTO shift oil seal #2
Not real familiar with the IH models, but wondering if you got this fixed? I would think you have to remove the rockshaft/top cover to access.
I am going to try and change the seal and see what happens. I haven't used anything off the PTO. I don't use the tractor that much in the winter. Next summer I will look at it again, when I try and use the PTO. It turns free and engages. I think the clutch is gone as I have to stop and engage it as the engine is stopping. It will grind when I push the clutch in trying to engage the PTO. Thanks for the input
2003 Ford Ranger XLT Pickup Truck (A51692)
2003 Ford Ranger...
2018 Kubota M5-111 (A50123)
2018 Kubota M5-111...
2016 Kenworth T880 Tri-Axle Brenner Tanker Truck (A51692)
2016 Kenworth T880...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
1984 Utility 44 ft. Reefer Trailer (A53117)
1984 Utility 44...
