1970 JD 400 Industrial
   / 1970 JD 400 Industrial #1
70jd400
Fitzwilliam NH
JD 400 Industrial
Hi. I am new here. I just got a new to me JD 400. All in all it seems to be a decent machine. I am having trouble with the fuel gauge. It always says full. I found that the wire going to the tank wasn't there so I fixed that. But the gauge still doesn't change it always says full. How do I know if that gauge not working or if it's the sending unit in the tank?
   / 1970 JD 400 Industrial #2
Im no help. When fuel gauge quits i use a measuring stick. Welcome to the forum. There is a guy that surfs the forum named txjim. If you can draw him to you situation I sure he can help. He's like a "Mr fix it/mechanical wizard" what ever he says I'd run with it.
   / 1970 JD 400 Industrial #3
Welcome to TBN
Thanks for the compliment Phillip w BUT there are also other members of this discussion forum that are as knowledgeable or more knowledgeable than I am about JD tractors & equipment.
For checking gauge with ign switch in on position take sender wire off of sender & touch wire to tractor frame & IIRC gauge needle should move to empty. One can also remove sender(if fuel level permits) & with sender mounting area touching unpainted area of tank manually move float to check gauge operation.
Thanks Tx Jim. I will try that tonight.
Ok so I just got in from moving the wire to a ground spot. I used the light bracket as that is where the light is grounded to. The needle moved to empty when on a ground spot. So I take it that the gauge is ok and the sending unit is probably junk? 20170809_045234.jpg
   / 1970 JD 400 Industrial #6
In my experience, you have about a 95% chance that this test proves the sender is bad. I have had a couple rare occasions that the gauge is still bad even when it cycles from full to empty when grounded out. The only way to know for certain is to have a variable resistor or a known good sender to test the gauge. The reason is because the sender never goes to zero ohms like happens when grounding the wire.
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
UNUSED FUTURE 1R RIPPER (A51248)
UNUSED FUTURE 1R...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
