Oil & Fuel 1970 Ford 3000
   / 1970 Ford 3000 #1
parsonbw
NC
JD X500
OK, before I ask the question, get your laughing over.:laughing::laughing: I just bought a 1970 Ford 3000, with a three cylinder gas engine. Looking forward to working it.
Here's the question: Where in the world is the filler tube to add oil? Have looked high and low, literally.
(See, I told you that you would laugh.) Can you help me?
   / 1970 Ford 3000 #2
Engine oil?
Two possible positions:
On the valve cover on top of engine
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
On the engine's front cover, right side of engine
Watch #23A
I borrowed a picture from Ford Tractor Engines :
http://www.brokentractor.com/ford_files/ford-engine 007.jpg
It is a diesel, but the filler cap is on the same spot as on your gas engine.
The earlier position was integrated with the breather pipe (angled pipe) on the valve cover
No one is laughing. You probably expect the filler cap to be on top of engine, as it normally is.
   / 1970 Ford 3000
Thanks, hakan. It was on the top right side of the engine. BUT, you have to pull out the battery
to get to the oil fill cap. Wow! But the mystery is solved nevertheless.
Thanks again.
2019 VALTEK 2500HP FRAC PUMP (A45333)
2019 VALTEK 2500HP...
2015 Chevrolet Silverado 2500 LT 4x4 Extended Cab  6.0L V8 (A44789)
2015 Chevrolet...
2011 WESTERN STAR  4900EX (A45046)
2011 WESTERN STAR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A44789)
2021 New Holland...
2016 Peterbilt Tri-Axle Dump Truck (A42203)
2016 Peterbilt...
2018 LeeBoy 8520 Asphalt Paver  Kubota Diesel, Electric Legend Screed (A44789)
2018 LeeBoy 8520...
