1970 2520 Brakes
/ 1970 2520 Brakes #1
cantbeatadeere
Bronze Member
UPSTATE new york
I have a 70 2520 with 1800 hrs on it.....practically new. I have no other tractor similar to compare the brake operation to so it may be normal......the foot pressure needed for good braking seems very high, also when stopping or slowing a load you really have to use your head and anticipate what your doing. I load it on a tilt equipment trailer now and again and it takes more pressure than I feel it should just to hold its own weight...?...any ideas would be appreciated. THANKS in advance.
/ 1970 2520 Brakes #2
This tractor uses wet disc hydraulic brakes. You could check brake fluid levels. I don't know how wet disc brakes work but you may wish to start there.
/ 1970 2520 Brakes #3
Have you attempted to bleed the brakes? Bleeders are on the inside top of rear axle housings
/ 1970 2520 Brakes #4
Might want to check that brake pedals pivot freely on pivot pin. I have seen some low hour tractors get sticky from lack of use. Also brake valve could be sticking. You should be able to lock up rear wheels without excessive force.
