1968 massey 135 cont. gas tractor 3 pt lift. slow liftting.
   / 1968 massey 135 cont. gas tractor 3 pt lift. slow liftting. #1
boomer05
bartlesville ok.
suzue m2000
will lift brushhog but is real slow and the levers have to be nearly all the way up to lift.oil is clean.pump circulates a good flow.thanks
   / 1968 massey 135 cont. gas tractor 3 pt lift. slow liftting. #2
Although your pump flow is good, it might not be getting to the 3pt cyl, and if it does, it could be leaking by the cyl seals.
The relief valve might be leaking.
Install a hyd gage and test the pressure while lifting or max out the 3pt cyl and read the pressure.
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
TRUCK BED PORTABLE FUEL TANK (A51248)
TRUCK BED PORTABLE...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
