1968 JD 300 Hydraulic Pump Identification
   / 1968 JD 300 Hydraulic Pump Identification #1
joecooler
Huntsville, AL
1968 JD 300 Industrial
Hi guys, how do I know the capacity of my Hydraulic pump? I have three choices. 6.5GPM, 13GPM or 23.5GPM.
I think I found it. 13.5 GPM AR103033.
   / 1968 JD 300 Hydraulic Pump Identification #3
I see you already found it.
6.5gpm was without power steering
13gpm was with power steering
23.5gpm was an option, which I doubt not very many, if any had.
Thank you for the information. Mine is a power steering model. Good nugget.
   / 1968 JD 300 Hydraulic Pump Identification #5
Are you positive 6.5 gpm pump wasn't utilized on earlier models below serial # 045,200 that could have open center power steering?
There is a pre serial number range consideration for the pump. Mine is a later model.
   / 1968 JD 300 Hydraulic Pump Identification #7
I went by the serial number he posted
   / 1968 JD 300 Hydraulic Pump Identification #8
Sorry I misunderstood your reply. I thought you were referring to all yr models.
   / 1968 JD 300 Hydraulic Pump Identification #9
No worries
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
2021 BOBCAT T64 R-SERIES SKID STEER (A51246)
2021 BOBCAT T64...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
