Buying Advice 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions??
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #1
65plymouth
Metamora, MI
None
Hello. New guy here...
My family just purchased some property and I am looking at buying a tractor. Looking for something in the 40-60 hp range, 2 wheel drive, DIESEL, Live Hydraulics... and capable of running a tiller, Disc, 2-3 bottom plow and good size brush hog. Would like opinions from the experts. My budget is about $6000-$6500 max for the tractor. I am not looking for a project or something that needs a ton of maintenance. Parts availability is also important. Don't want to buy something, break a part, and find out that the part is "unobtainable". Not afraid to drive up to 500 miles for the right tractor.
So far.. I have been considering the following
Ford - 3600/4600. Was told to stick with the 3 cylinder diesel. Not completely sold on the Fords for some reason. Never considered myself a "ford guy"
Massey Ferguson - 150/165/255. I really like the Massey offerings but have been told to stay away from "Multipower". Also having a hard time finding anything worthwhile here in Michigan or even Ohio. Most everything is in Kentucky and Tennessee. ***Other than age, can anyone tell me the mechanical differences between the 165 and 255? Looks like there is A LOT of overlap.
IH 574 - Just started looking into this one as there are a few local offerings.
What else should I be looking at? I haven't even considered "green" as they tend to be over budget compared to similar options of the ones above.
Suggestions
Thanks
Jeff
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #2
I had a Ford 4600 that was around 45-50 hp. 3 cyl diesel. Really nice, reliable tractor. I have had more Fords over the years than any and they are well built and parts are plentiful.
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #3
Ford built some great tractors in that era. A Ford "10" series, 3910 or 4610 would be my pick.
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #4
Ford parts available for a reasonable price is probably about the best there is.
Anything in the 4000-5000 series 3-cyl
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #5
I'm afraid most of the ag tractors of that era will not have a low enough gear for a tiller.
I have a 574, it's a nice nimble tractor, hard starting in the winter. A lot of the utility tractors
of that era you sit down into straddling the transmission and hydraulics it will get uncomfortably hot
in the summer. Don't be afraid of the Olivers, 1550 &1650 or Allis Chalmers the 140 -160's parts are available,
and they are relatively easy to work on.
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #6
Suggestions
Thanks
Jeff
As suggested above!
The Fords in your price range are the BEST tractors out there.
Thanks for the suggestions guys. I will look into a few of the models mentioned.
I have looked at the Fords but the 2 I was looking at here in Michigan (both 3600s) seemed very over priced. I will take a look for other Ford models as suggested.
So what about the Masseys? Seems as everything I read about the 135, 150, 165, 245, 255 is that they are great tractors with any easy to work on/rebuild perkins? Thoughts?
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #8
I've always been partial to the JD 2020 / 3020 tractor. Probably more nostalgia than logic behind that though.
   / 1965-1980 - 2 Wheel Drive - 40/60hp Suggestions?? #10
I have a friend with a Massey 225, and I have used his.
That 225 Massey is a GREAT old tractor!
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
(APPROX 12) 2" X 6" X 41" IRON TUBING (A51247)
(APPROX 12) 2" X...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
(APPROX 14) 3 1/4" X 6" X 68" THICK IRON BEAM (A51247)
(APPROX 14) 3 1/4"...
