1963 Ford 2000 Runs then dies
   / 1963 Ford 2000 Runs then dies #1
Beavonrhebayou
DeRidder, Louisiana
1963 Ford 2000
Hi all,
I'm a first time tractor owner and I bought a 1963 Ford 2000 gas tractor for our new property. Before I hooked up any implements, it ran great. As soon as I hooked up the bush hog, it cut for about 25 yards, then sputtered and died. It won't do any better, so I started investigating. Here's what I've found. Under load, it sputters, loses power, and dies rather quickly.
1. It has good fuel flow to the carburetor. I removed the inline filter the previous owner put on it, and I replaced the sediment bowl assembly. Fuel streams out if the valve is open.
2. If I turn the fuel off as soon as it dies and open the fuel drain on the bottom of the carburetor, I don't get 1/4 to 1/2 cup of fuel, more like 2 tablespoons. If I leave the fuel valve on with the drain plug open, fuel doesn't stream out. It starts out strong, then peters out.
3. I disassembled, thoroughly cleaned, and rebuilt the M/S TSX 765 carb, and it still does it, albeit a bit smoother.
4. It has a new distributor cap, plugs, plug wires, and has been converted to electronic ignition.
Any help would be awesome..!!
Thanks,
Joel
   / 1963 Ford 2000 Runs then dies #2
Just a wild guess... is there a fuel tank vent that is clogged?
I have engines run perfect and then die is sputter... more than once it was a plugged fuel cap vent.
Fuel ran fine when I pulled the hose... guessing the larger diameter hose let air in.
Maybe try with fuel cap off for a couple of minutes?
   / 1963 Ford 2000 Runs then dies #3
have you checked the fuel filter. Look to see if someone has installed some type of inline filter also
   / 1963 Ford 2000 Runs then dies #4
Pull the cap off the fuel tank and try it again. Cap is supposed to be vented. Vent gets clogged, blocking off replacement air in tank as engine uses it, creates a slight vacuum and inhibits fuel from flowing out. The other thing is the muffler is right under the tank which heats the fuel, making it more volatile and chance of vapor lock is present.....vapor lock: fuel boiling at a restriction in the line, limiting the amount of fuel in the line to the carb.
Both are vacuums of different sources/sorts.
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2006 Ford Explorer 4x4 SUV (A51694)
2006 Ford Explorer...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
