1960's John Deere 2010 utility tractor power steering issue
   / 1960's John Deere 2010 utility tractor power steering issue #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
1960's John Deere 2010 utility tractor power steering issue. I am a retired Mechanical Maintenance person wanting to help my son, who is a hobby farmer. I am looking for some verbal help or pictures relating to a 1960's John Deere 2010 utility tractor power steering issue. The tractor has developed a hard turning issue. I understand most of the items in a power steering system, but need help from some one who's had a 2010 or worked on a 2010 power steering issue. What kind of reservoir, pump, steering column valve & steering cylinder is on that tractor. Where can I get a hydraulic power steering diagram. Any help is appreciated.
   / 1960's John Deere 2010 utility tractor power steering issue #4
If you go on Google and search for "Bundy Bears Shed Deere steering" you'll find a couple videos where goes through pretty much everything about these systems.
Thank You
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
Light Tower (A52377)
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
FAKE (A52472)
FAKE (A52472)
