1958 Clark Michigan Loader
   / 1958 Clark Michigan Loader #11
I also have a model 85ag Michigan loader 6cyl gas and need head gasket as it is fireing between 2 cyl
   / 1958 Clark Michigan Loader #12
About the Zenith carb floats I found that the float from a Farmall H is the same as the float in the 75A carb. I bought just the float from a used tractor parts yard for $20.00. Has been working for about 5 years now. When I had the carb problem, I bought some gas from a country store that sells a little gas once in a while. There was some water in it and over the winter it froze in the float bowl where it squeezed the float. Since I put a kit and used float in that carb, I remove the plug on the bottom of the bowl and drain the gas every fall, and after each use in freezing weather. Machine is a 1958 model 75A "roadster" (no cab) with forks. Hawgfan in Arkansas
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
2019 F150 (A56435)
2019 F150 (A56435)
