1955 Ford 640 Distributor Mechanical Advance
   / 1955 Ford 640 Distributor Mechanical Advance #1
JStorch
Sullivan, Ohio
1955 Ford 640
I ended up as the caretaker for a community owned tractor. She ran pretty good in the 800- 1700 RPM range but wouldn稚 idle lower and was balky at higher RPM痴. Today I put a timing light to her and confirmed the mechanical advance simply doesn稚.
A look inside the distributor revealed 50+ years of rust and assorted goop. I pulled the weights and cleaned them, however before I put them back in I would like to find out what the proper lubricant is for the weights. I have to go find breaker cam grease and may as well pick up the right lube for the weights.
Thanks,
John
   / 1955 Ford 640 Distributor Mechanical Advance #2
that napa ML1 you are putting on the cam lobe is fine for the flywheights too.
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
