1953 model D
/ 1953 model D #1
almost13ranch
John Deere 3120
Can anyone direct me to a resource for trouble shooting the charging system on a 1953 model D tractor? I would like step by step directions if possible.
/ 1953 model D #2
I don't know of any online source, but the "D" used a 6 volt positive ground system. It used a generator with a regulator bolted right on it. A quick test to see if the generator will charge is to use a jumper lead to ground the field terminal. The field terminal should be marked with an "F". That bypasses the regulator. If it charges with field grounded, then the generator is good and the regulator is bad. If it does not charge , then the generator is not charging, and needs to be rebuilt or replaced. Anytime a generator or regulator is replaced, it needs to be polarized. Do this by momentarily touching a jumper wire between the BAT terminal on the regulator and the GEN terminal. Good Luck!
/ 1953 model D #3
If the tractor has not been run for a long time, the generator may just need to be repolarized.
/ 1953 model D #4
I like to read johnnypopper.com. There are some knowledgeable folks over there. I have a '29 D and dad has a 37 and a 38 D. Love the lumbering old workhorses.
Brent
2022 EZ-GO ELITE...
2006 John Deere 5425 (A64126)
2006 John Deere...
2022 EZ-GO ELITE...
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
