1953 Ford Golden Jubilee NAA sputtering
   / 1953 Ford Golden Jubilee NAA sputtering #1
cobalt650
Waunakee, WI
Kubota MX5200
I went "Up North" to cut some grass with our 1953 Ford NAA. It has a gas shut off valve, and is only filled with Ethanol free Premium with Sea Foam. It hadn't been started in a few months. Started well, but I had to keep the choke out to keep it running. Cranked up the idle, was able to cut some grass. Then it would only sputter, with the choke full out. Quit if the choke was in. Not sure the nuts/bolts will survive if I pop the 65 year old carb off. Think I could spray some carb cleaner in the main jet screw opening? Or maybe just buy a new carb and swap it out? Time is at a premium, it is located 4 hours from home in Northern Wisconsin. Thanks much,
Steve
   / 1953 Ford Golden Jubilee NAA sputtering #2
I would bet the carb bolts will do fine. Check the main jet. Ed
Ed,
Is the main jet the one that you can screw out by hand? Thanks!
   / 1953 Ford Golden Jubilee NAA sputtering #4
uh.. that would be the main needle. ;)
you can of course try pulling the needle and fuel line, and opening the carb drain and using a can of carb cleaner with straw and get a few blasts thru main, ( and idle ), and then a few good streams thru inlet. note the inlet has a specific passageway.. don't try to do it blind.
Pulled the main needle, shot some carb cleaner in, runs like an Indy Car:)
   / 1953 Ford Golden Jubilee NAA sputtering #6
good deal.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2024 JOHN DEERE FC20M LOT IDENTIFIER 71 (A53084)
2024 JOHN DEERE...
