1951 john deere a
   / 1951 john deere a #1
ny
jd 1070
hi guys i have a 1951 john deere a that last year pulled my 12 ft kba disk no problem in 3 gear now if i try that it stalls tractor out so i tryed 2 gear it pulls it but i get smok cumming from clutch housing not sure whats going on any help thanks art
   / 1951 john deere a #2
Sounds like you may need to adjust the power adjusting screw on the carb. not the idle screw the other one. turn it out 1/4 turn and see if it helps. Smoke from the clutch says it's slipping. Pull the cover and adjust it.
   / 1951 john deere a #3
A 1951 JD Model A got me curious as to what it would look like compared to the earlier version...
Then I came across this cool picture:
   / 1951 john deere a
yes been it is the kabouta problem was a dirty injector they fixed tah and it ran great my john der a puleed it fine in 3 gear about 2 weeks ago tried it yester day and motor lugs down just trying to start pulling disk in 3 it pulls it in 2 but not f good seems to not have any power it runs unloade fine not sure whats going ion
art
   / 1951 john deere a #6
You can start by checking compression.. maybe time for an engine overhaul.. assume the brake lock didn't get flipped and one brake is dragging..
a bit more history if you want analysis just based on what has been told.. IMO
   / 1951 john deere a
i did run out of gas befor the issue came up had some trouble getting it to start after i put gas in had to take out the bowl drain plug to get gas flowing but then it started really goood but still had the power issue
   / 1951 john deere a #8
Did you clean the glass sediment bowl? It sounds like you got the junk in the bottom of the tank in the fuel system. Sediment bowl may be full of water.
12in Auger Mini Skid Steer Attachment (A51691)
12in Auger Mini...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
