1951 Ferguson TO 20
   / 1951 Ferguson TO 20 #1
jones6780
Lizella, Ga.
Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
So I just traded for a TO 20 and brought it home. It runs and operates but needs a little TLC. I am not going to restore it just freshen it up a bit. Ferguson.jpg
   / 1951 Ferguson TO 20 #2
Cool! My neighbor picked up a TE-20 he plans to restore. The difference is the TE was produced in England and the TO was produced overseas - America. Interestingly, Harry Ferguson invented the three point.
   / 1951 Ferguson TO 20 #3
That's a good tractor, I have owned his big brother, TO 35 for 39 years and done a lot of hard work with it.
   / 1951 Ferguson TO 20 #4
I have a broken down one (cracked block) in the shed. I would like to restore it someday since it goes back in the family 3 generations.
My gas tank leaks from the outlet fitting, valve cover leaking, wrong starter solenoid, gauges not working, master brake pedal only operates one side, oil on brake shoes, paint, just to name a few things she needs.
Taking a few things off to clean and paint, dash/steering column, hood. The valve cover was leaking bad and the gasket was missing from about 6 inches. Been using oven cleaner to degrease/depaint the tough stuff that was baked on. Then pressure wash to clean the rest. Looking for suggestions on cleaning the inside of the engine, really caked with crud. Got some parts ordered, just got to get ready to put the parts on, and see what else I need.
Got to clean out the gas tank too!
I need photos of the brake linkage on both sides of a TO20. Mine has something wrong/missing. Master pedal has linkage missing from right and left releases instead of braking when pressing master pedal.
   / 1951 Ferguson TO 20 #8
Cleaning out the inside of the engine is tough, if you were to use an additive to loosen a lot of sludge you are taking a chance that it will plug your oil pump pick up. Use a good grade of detergent oil and change it frequently, you might help it a lot.
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
2020 INTERNATIONAL LT625 DAY CAB (A53426)
2020 INTERNATIONAL...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
