1951 B - Temperature Question
   / 1951 B - Temperature Question #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
My new (old) 1951 JD B's temperature gauge isn't showing any temperature - even after 2 hours of spreading manure. The unit doesn't seem hot and the blinds arn't too hot with the air. However, if the gauge isn't showing anything, should I be thinking the gauge and sensor are bad and they should be changed out?
Someone had told me there is a kit that combines all together - is this true?
Happy to get recommendations and thoughts from the folks here.
Thanks for your help!
-Bob
   / 1951 B - Temperature Question #4
If you want a restoration quality gauge contact Jerry Trcka. His are correct and will read right. I got one years ago for my A (first tractor) from one of the other parts suppliers that always reads low, total waste of money. Google his hame or use Facebook.
   / 1951 B - Temperature Question #5
Just drain the coolant level down below where the sensing bulb goes in. Once you remove the sensing bulb it is very easy to test the temp gauge, by putting the bulb in a small pot or cup of boiling water. Then see if the gauge works.
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
2022 PETERBILT 579 DAY CAB (A53426)
2022 PETERBILT 579...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
