1950 John Deere G
   / 1950 John Deere G #1
new oxford, pa.
2003 kubota bx2200, 1946 john deere B, 1950 john deere G
Have a question for any 2 cylinder gurus in here... Was wondering if you can change out a connecting rod on a 1950 G from the access plate on top of the motor or do you have to pull the valve cover and head and pull out the front? Thanks in advance.
   / 1950 John Deere G #2
Don't know the answer to that, but suspect need to do more than the access plate... Try looking over some of the youtube videos, one in particular is a series .. one of which is rebuild 002.. may have to get to 005 or 006 to see what you need.
John Deere Model A tractor rebuild 2 - YouTube
This may help you see what is "inside" of the G, and likely is close to the Model A.
Hope you let us know more about where you are at.
   / 1950 John Deere G #3
You can change a rod bearing but not a rod from the access cover. Head has to come off to remove the wrist pin.
   / 1950 John Deere G #4
Ditto what RickB stated.
   / 1950 John Deere G
Finally got to it here tonight and the answer is yes you can change the connecting rod from the top cover with some patience, just had to try it since they said you couldn't do it lol.
Just need to clean crank up a little and size up the bearings and it will be back together. Thanks for the reply's this site is awesome and very useful.
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A51573)
New/Unused AGT...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2019 CHEVROLET SILVERADO 1500 (A52472)
2019 CHEVROLET...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
